[OpenLayers-Users] postgresql table to Geojson and diplay it in openlayers
javad sadidi jsadidi at gmail.com
Wed Aug 24 13:32:34 EDT 2011
hi
I have a table in postgresql that it has topology and I want to display it
as line in openlayers.
I use php to connect and convert my data to Geojson. this the codes.but I
can not  get the result.who can help me.where is wrong in my codes,this is
the code.
<?php
   // Database connection settings
   define("PG_DB"  , "tehran");
   define("PG_HOST", "localhost");
   define("PG_USER", "postgres");
   define("PG_PORT", "5432");
   define("TABLE", "close");
<?php
// Connect to database
   $dbcon = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER);
   $sql = "SELECT gid, ST_AsGeoJSON(the_geom) AS geojson, length(the_geom)
AS length FROM ".TABLE.""
   // Perform database query
   $query = pg_query($dbcon,$sql);
<?php
   // Return route as GeoJSON
   $geojson = array(
      'type'      => 'FeatureCollection',
      'features'  => array()
   // Add edges to GeoJSON array
   while($edge=pg_fetch_assoc($query)) {
      $feature = array(
         'type' => 'Feature',
         'geometry' => json_decode($edge['geojson'], true),
         'crs' => array(
            'type' => 'EPSG',
            'properties' => array('code' => '4326')
            'id' => $edge['id'],
            'length' => $edge['length']
      // Add feature array to feature collection array
      array_push($geojson['features'], $feature);
   // Close database connection
   pg_close($dbcon);
   // Return routing result
   header('Content-type: application/json',true);
   echo json_encode($geojson);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110824/8ba64070/attachment.html
