[OpenLayers-Users] best way to convert an OL map to a static map ?
Julien Cigar
jcigar at ulb.ac.be
Wed Aug 31 08:55:27 EDT 2011
Hello,
I have a webapp where the user wants to be able to download a "static
version" of the displayed OL map, and I wondered what's the best way to
do it ..?
I'm using PostGIS/Mapserver and a (dynamically generated) SLD stylesheet.
I planned to simply use the &mode=map of Mapserver, problem is that SLD
is only supported with WMS requests, so I have to translate my SLD to
MAP syntax (classes, styles, etc).. which I like to avoid.
So I wondered if there is a better way to do than playing with the URL
parameters (BBOX, LAYERS, etc)? Also, I would like to keep the
'attribution' propert(y|ies) of the active(s) layer(s) if possible (I
use this property to put a custom logo on the map).
Thanks,
Julien
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110831/05946bfb/jcigar-0001.vcf
