[OpenLayers-Users] Openlayers IE8 Click Clustered Feature
Jerry O'Sullivan
jeremiahosullivan at gmail.com
Mon Dec 5 11:02:06 EST 2011
Hi.
I have a vector layer with some data clustered, I can create a label with
the number of items at a point with the code below
I am having problems in IE8 using the selectfeature event as the label
takes the select event and does not seem to pass it down to the icon. I can
get
the event fired if I click just outside the label otherwise I cannot get
the even fired
Any ideas on this?
It works fine on FF! but I must get it working in IE8
Thanks,
J
var vecdata_clustered_rule = new OpenLayers.Rule({filter: new
OpenLayers.Filter.Comparison({type:
OpenLayers.Filter.Comparison.GREATER_THAN,
property: 'count',
value: 1
symbolizer: {'fillColor': '#377EB8',
'fillOpacity': 0.8,
'strokeWidth': 0,
'pointRadius': 6,
'label' : '${count}' , //
'fontWeight' : 'bold' ,
'graphicName' : 'circle'}
var sel_feat_q = new OpenLayers.Control.SelectFeature(vec_data_q,{multiple:
true, toggle: true });
map.addControl(sel_feat_q);
sel_feat_q.activate();
vec_data_q.events.register('featureselected', this,displayinfo) ;
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111205/5938723b/attachment.html
