[OpenLayers-Users] Tweening pinpoints
Adam Eskreis aeskreis at gmail.com
Tue Dec 6 13:03:05 EST 2011
There is an OpenLayers.Tween class I believe.
Also, this is something that could easily be done iwth just regular
javascript.  Don't forget, OpenLayers is comprised of DOM elements, so you
can manipulate the map with regular javascript, you don't have to use an
OpenLayers construct.
On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>wrote:
> Hello,
> I'm currently using OpenLayers.Control.DragFeature to move pinpoint from
> one place to another.
>         var dragFeature = new OpenLayers.Control.DragFeature(location);
>                          map.addControl(dragFeature);
>                          dragFeature.activate();
> But not only moving pinpoints, I need to add tween animation.
> Has anyone done tween animation for moving pinpoints?
> Any advise would be much appreciated!
> Thanks
> Takako
> http://www.bbc.co.uk
> This e-mail (and any attachments) is confidential and may contain personal
> views which are not the views of the BBC unless specifically stated.
> If you have received it in error, please delete it from your system.
> Do not use, copy or disclose the information in any way nor act in
> reliance on it and notify the sender immediately.
> Please note that the BBC monitors e-mails sent or received.
> Further communication will signify your consent to this.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111206/bbc87813/attachment-0001.html
