[OpenLayers-Users] Tweening pinpoints
Takako Tucker
Takako.Tucker at bbc.co.uk
Wed Dec 7 04:55:24 EST 2011
Thanks for this! I had a look at .Tween, but as it reacts to DOM
elements I couldn't be sure if it works with Lon Lat (X.Y) figure.
I'll try again later on though.
Sent: 06 December 2011 18:03
To: Takako Tucker
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Tweening pinpoints
There is an OpenLayers.Tween class I believe.
Also, this is something that could easily be done iwth just regular
javascript. Don't forget, OpenLayers is comprised of DOM elements, so
you can manipulate the map with regular javascript, you don't have to
use an OpenLayers construct.
On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>
wrote:
Hello,
I'm currently using OpenLayers.Control.DragFeature to move
pinpoint from one place to another.
var dragFeature = new
OpenLayers.Control.DragFeature(location);
map.addControl(dragFeature);
dragFeature.activate();
But not only moving pinpoints, I need to add tween animation.
Has anyone done tween animation for moving pinpoints?
Any advise would be much appreciated!
Thanks
Takako
http://www.bbc.co.uk
This e-mail (and any attachments) is confidential and may
contain personal views which are not the views of the BBC unless
specifically stated.
If you have received it in error, please delete it from your
system.
Do not use, copy or disclose the information in any way nor act
in reliance on it and notify the sender immediately.
Please note that the BBC monitors e-mails sent or received.
Further communication will signify your consent to this.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
http://www.bbc.co.uk/
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of the BBC unless specifically stated.
If you have received it in error, please delete it from your system.
Do not use, copy or disclose the information in any way nor act in reliance on it and notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111207/db477aa3/attachment-0001.html
