[OpenLayers-Users] map doesn't align with Google maps when accessed via a proxy
Andreas Hocevar ahocevar at opengeo.org
Wed Dec 7 04:32:54 EST 2011
Don't forget to configure your map with the appropriate options for
Web Mercator layers:
    projection: "EPSG:3857",
    units: "m",
    maxResolution: 156543.0339,
    maxExtent: [-20037508.34, -20037508.34, 20037508.34, 20037508.34]
Andreas.
On Tue, Dec 6, 2011 at 11:46 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
> I have a simple WMS (served by MapServer) overlaid on a Google Map baselayer defined like so
>        var layer = new OpenLayers.Layer.WMS(
>                "Layer name",
>                "http://path/to/cgi-bin/app",
>                {layers: "layer", transparent: true},
>                {isBaseLayer: false, opacity: 0.6}
> The above works very well but, now I have to get the above layer via a proxy. As is, I end up getting the complete map repeated in every tile. So, I changed the layer definition to the following
>                "Layer name",
>                "http://path/to/proxy/app",
>                {isBaseLayer: false, opacity: 0.6, singleTile: true}
> Now I get a single complete map, however, it doesn't align with the Google Map baselayer. I tried adding `sphericalMercator: true` to the layer definition but no joy.
> Suggestions?
> Puneet Kishor_______________________________________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
