[OpenLayers-Users] map doesn't align with Google maps when
accessed via a proxy
Puneet Kishor
punk.kish at gmail.com
Wed Dec 7 10:42:59 EST 2011
Hi Andreas,
On Dec 7, 2011, at 3:32 AM, Andreas Hocevar wrote:
> Don't forget to configure your map with the appropriate options for
> Web Mercator layers:
> projection: "EPSG:3857",
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: [-20037508.34, -20037508.34, 20037508.34, 20037508.34]
Yes, of course. My map is configured with the above options, and as I said in my original post, it works just fine when retrieved directly as a WMS from OpenLayers. However, as I also said, I need to experiment with a request via a proxy. When I do that, I end up getting either a complete map per tile request, or, if I use singleTile:true, I do get a single map correctly but the map is shifted completely.
I am passing to the proxy all the parameters that OpenLayers is sending, so MapServer is receiving everything that it would have received directly.
> On Tue, Dec 6, 2011 at 11:46 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>> I have a simple WMS (served by MapServer) overlaid on a Google Map baselayer defined like so
>> var layer = new OpenLayers.Layer.WMS(
>> "Layer name",
>> "http://path/to/cgi-bin/app",
>> {layers: "layer", transparent: true},
>> {isBaseLayer: false, opacity: 0.6}
>> The above works very well but, now I have to get the above layer via a proxy. As is, I end up getting the complete map repeated in every tile. So, I changed the layer definition to the following
>> "Layer name",
>> "http://path/to/proxy/app",
>> {isBaseLayer: false, opacity: 0.6, singleTile: true}
>> Now I get a single complete map, however, it doesn't align with the Google Map baselayer. I tried adding `sphericalMercator: true` to the layer definition but no joy.
>> Suggestions?
>> Puneet Kishor_______________________________________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
