[OpenLayers-Users] Questions about Filtering WFS
Phil Scadden p.scadden at gns.cri.nz
Wed Dec 7 15:31:12 EST 2011
On 8/12/2011 6:09 a.m., Diego M. wrote:
> the problem is when i load the map, the points take while befor they appear.
Strongly consider using WMS to display and WFS to query instead.
> 1- how i can make sure about that the distance is in the units of  native
> projection ?
> 2- my distance is 4250, what does it mean exactly ? and wich unit ?
> 3- does the property in the filter means the column ?
> 4- the point is the center of the map and the distance is the raduce, right
This depends on the server. I believe mapserver honours distanceUnits:
but geoserver doesnt.
You need to convert the distance into native projection (application
knowledge).
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
