[OpenLayers-Users] Tweening pinpoints
Casper Span
info at spatially-oriented.com
Wed Dec 7 15:55:51 EST 2011
Hi Takako,
In my example I wanted the map to move.
However, it should be fairly easy to adapt the code to your liking.
Basically what I do is letting the tween class calculate my path & timing,
and on eachStep I move the map. On eachStep, you should move your pinpoint
with something like this: (NOTE: not tested)
someFunc: function() {
// var fromCoord = your starting point
// var toCoord = your destination point
// var duration = number of steps it should take, the more you take, the
smoother the ride & longer it will take. (unless you also change the
INTERVAL constant on Tween)
var callbacks = {
eachStep: tweenstep
var tween = new OpenLayers.Tween(OpenLayers.Easing.Quad.easeInOut);
tween.start(fromCoord, toCoord, duration, {callbacks: callbacks}
tweenstep: function (value) {
// TODO: move your feature to the new coord
// given in value.x and value.y
And another note: the tweenstep function is being called from the tween
class, so you are out of scope and cannot see your feature. That's why, in
my blogpost, I also stored the map object into the tween. You will probably
have to do something similar with your feature.
If you can't get this to work, I might be able to set up a sample
somewhere. Also, you might have some luck looking at the developer example
code:
http://openlayers.org/dev/tests/manual/tween.html
regards,
Casper
On Wed, Dec 7, 2011 at 6:39 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>wrote:
> Hi, so this is what I currently got.
> http://paste.org/41978
> I can't seem to see Tweening working between pinpoints... Any advise would
> be much appreciated.
> The map shouldn't move and just pinpoints should move...
> Takako
> *From:* Casper Span [mailto:info at spatially-oriented.com]
> *Sent:* 07 December 2011 10:38
> *To:* Takako Tucker
> *Cc:* Adam Eskreis; openlayers-users at lists.osgeo.org
> *Subject:* Re: [OpenLayers-Users] Tweening pinpoints
> I dabbled a bit with this a few weeks ago and posted a small blog on it...
> Maybe it helps.
> http://www.spatially-oriented.com/joomla/tech/34-gis-articles/59-animated-zoom-with-openlayers
> On Wed, Dec 7, 2011 at 10:55 AM, Takako Tucker <Takako.Tucker at bbc.co.uk>wrote:
>> Thanks for this! I had a look at .Tween, but as it reacts to DOM elements
>> I couldn't be sure if it works with Lon Lat (X.Y) figure.
>> I'll try again later on though.
>> *From:* Adam Eskreis [mailto:aeskreis at gmail.com]
>> *Sent:* 06 December 2011 18:03
>> *To:* Takako Tucker
>> *Cc:* openlayers-users at lists.osgeo.org
>> There is an OpenLayers.Tween class I believe.
>> Also, this is something that could easily be done iwth just regular
>> javascript. Don't forget, OpenLayers is comprised of DOM elements, so you
>> can manipulate the map with regular javascript, you don't have to use an
>> OpenLayers construct.
>> On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>wrote:
>>> Hello,
>>> I'm currently using OpenLayers.Control.DragFeature to move pinpoint from
>>> one place to another.
>>> var dragFeature = new OpenLayers.Control.DragFeature(location);
>>> map.addControl(dragFeature);
>>> dragFeature.activate();
>>> But not only moving pinpoints, I need to add tween animation.
>>> Has anyone done tween animation for moving pinpoints?
>>> Any advise would be much appreciated!
>>> Thanks
>>> Takako
>>> http://www.bbc.co.uk
>>> This e-mail (and any attachments) is confidential and may contain
>>> personal views which are not the views of the BBC unless specifically
>>> stated.
>>> If you have received it in error, please delete it from your system.
>>> Do not use, copy or disclose the information in any way nor act in
>>> reliance on it and notify the sender immediately.
>>> Please note that the BBC monitors e-mails sent or received.
>>> Further communication will signify your consent to this.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> stated.
>> Users mailing list
> This e-mail (and any attachments) is confidential and may contain personal
> views which are not the views of the BBC unless specifically stated.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111207/0544d667/attachment.html
