[OpenLayers-Users] Tweening pinpoints
Takako Tucker
Takako.Tucker at bbc.co.uk
Thu Dec 8 04:24:09 EST 2011
Thanks Casper. Much appreciated. I'll test it now. :)
From: Casper Span [mailto:info at spatially-oriented.com]
Sent: 07 December 2011 20:56
To: Takako Tucker
Cc: Adam Eskreis; openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Tweening pinpoints
Hi Takako,
In my example I wanted the map to move.
However, it should be fairly easy to adapt the code to your liking.
Basically what I do is letting the tween class calculate my path &
timing, and on eachStep I move the map. On eachStep, you should move
your pinpoint with something like this: (NOTE: not tested)
someFunc: function() {
// var fromCoord = your starting point
// var toCoord = your destination point
// var duration = number of steps it should take, the more you take, the
smoother the ride & longer it will take. (unless you also change the
INTERVAL constant on Tween)
var callbacks = {
eachStep: tweenstep
var tween = new OpenLayers.Tween(OpenLayers.Easing.Quad.easeInOut);
tween.start(fromCoord, toCoord, duration, {callbacks: callbacks}
tweenstep: function (value) {
// TODO: move your feature to the new coord
// given in value.x and value.y
And another note: the tweenstep function is being called from the tween
class, so you are out of scope and cannot see your feature. That's why,
in my blogpost, I also stored the map object into the tween. You will
probably have to do something similar with your feature.
If you can't get this to work, I might be able to set up a sample
somewhere. Also, you might have some luck looking at the developer
example code:
http://openlayers.org/dev/tests/manual/tween.html
regards,
Casper
On Wed, Dec 7, 2011 at 6:39 PM, Takako Tucker <Takako.Tucker at bbc.co.uk>
wrote:
Hi, so this is what I currently got.
http://paste.org/41978
I can't seem to see Tweening working between pinpoints... Any
advise would be much appreciated.
The map shouldn't move and just pinpoints should move...
Takako
Sent: 07 December 2011 10:38
To: Takako Tucker
I dabbled a bit with this a few weeks ago and posted a small
blog on it... Maybe it helps.
http://www.spatially-oriented.com/joomla/tech/34-gis-articles/59-animate
d-zoom-with-openlayers
On Wed, Dec 7, 2011 at 10:55 AM, Takako Tucker
<Takako.Tucker at bbc.co.uk> wrote:
Thanks for this! I had a look at .Tween, but as it
reacts to DOM elements I couldn't be sure if it works with Lon Lat (X.Y)
figure.
I'll try again later on though.
Sent: 06 December 2011 18:03
To: Takako Tucker
Cc: openlayers-users at lists.osgeo.org
There is an OpenLayers.Tween class I believe.
Also, this is something that could easily be done iwth
just regular javascript. Don't forget, OpenLayers is comprised of DOM
elements, so you can manipulate the map with regular javascript, you
don't have to use an OpenLayers construct.
On Tue, Dec 6, 2011 at 12:33 PM, Takako Tucker
Hello,
I'm currently using
OpenLayers.Control.DragFeature to move pinpoint from one place to
another.
var dragFeature = new
OpenLayers.Control.DragFeature(location);
map.addControl(dragFeature);
dragFeature.activate();
But not only moving pinpoints, I need to add
tween animation.
Has anyone done tween animation for moving
pinpoints?
Any advise would be much appreciated!
Thanks
Takako
http://www.bbc.co.uk
This e-mail (and any attachments) is
confidential and may contain personal views which are not the views of
the BBC unless specifically stated.
If you have received it in error, please delete
it from your system.
Do not use, copy or disclose the information in
any way nor act in reliance on it and notify the sender immediately.
Please note that the BBC monitors e-mails sent
or received.
Further communication will signify your consent
to this.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
This e-mail (and any attachments) is confidential and
may contain personal views which are not the views of the BBC unless
If you have received it in error, please delete it from
your system.
Do not use, copy or disclose the information in any way
Please note that the BBC monitors e-mails sent or
received.
Further communication will signify your consent to this.
Users mailing list
This e-mail (and any attachments) is confidential and may
If you have received it in error, please delete it from your
system.
Do not use, copy or disclose the information in any way nor act
Please note that the BBC monitors e-mails sent or received.
system.
http://www.bbc.co.uk/
This e-mail (and any attachments) is confidential and may contain personal views which are not the views of the BBC unless specifically stated.
If you have received it in error, please delete it from your system.
Do not use, copy or disclose the information in any way nor act in reliance on it and notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111208/7d465eb9/attachment-0001.html
