[OpenLayers-Users] Select feature on multiple layers works just for one layer
Diego Pasqualin dpasqualin at gmail.com
Wed Dec 7 16:14:20 EST 2011
I see, your are right, that's the problem!! Thank you very much.
By the way, wouldn't be nice if all overlapping features get the event?
Something like the "event bubbling" on javascript?
2011/12/8 Andreas Hocevar <ahocevar at opengeo.org>
> Layers on top of each other yes. Features no.
> Andreas.
> On Dec 7, 2011 8:50 PM, "Diego Pasqualin" <dpasqualin at gmail.com> wrote:
>> According to this example is possible to get events from different
>> layers, but I just can't make it work =(
>> http://openlayers.org/dev/examples/select-feature-multilayer.html
>>> Hi,
>>> for features that sit on top of each other, you will only get events
>>> for the top one. Sounds like this is the reason for your problem.
>>> Andreas.
>>> On Sun, Dec 4, 2011 at 9:05 PM, Diego Pasqualin <dpasqualin at gmail.com>
>>> wrote:
>>> > Oh, I forgot to put this part of the code, which is run just after the
>>> > previous code:
>>> ---------------------------8<----------------------------------------------------------------------
>>> >         entities.layer_office.events.on({
>>> >             'featureselected': function (e) {onFeatureSelect(e.feature,
>>> > entity.map, control)},
>>> >             'featureunselected': function (evt)
>>> > {onFeatureUnselect(evt.feature, entity.map) }
>>> > ... the same for suburbs.suburbs_layer...
>>> > So, I create the control with the layers I want, and after that I use
>>> the
>>> > layers.events.on to run something when the a feature is selected.
>>> > This is practically the same I saw in some examples. What could be
>>> wrong?
>>> > 2011/12/3 emmexx <emmexx at tiscalinet.it>
>>> >> Il 12/02/2011 01:45 AM, Diego Pasqualin scrisse:
>>> >> > Any suggestion about what I might be doing wrong?
>>> >> Try using eventListeners instead of OnSelect?
>>> >> Or layer.events.on().
>>> >> Bye
>>> >>        maxx
>>> > _______________________________________________
>>> > Users mailing list
>>> > Users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111208/07d22c3f/attachment-0001.html
