[OpenLayers-Users] initialisation of style object
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Dec 8 01:30:56 EST 2011
Can you share your code snippet?
Is the radius available as a feature attribute? In that case you could use
something like {$radius}.
Best regards,
Bart
> hi list,
> I am trying to create a new style object.
> My start up code says
> var foo = new OpenLayers.Style({pointRadius:10})
> By the time it gets to the renderer object the style object should include
> the following value
> foo.pointRadius=45
> but in my case it actual reads
> foo.pointRadius=0
> I am not using the Stylemap object
> I had assumed the calling style object with the pointRadius set  like this
> would have correctly set up the style object.
> Which api call should I be calling to ensure this transformation happens?
> Regards
> Dave
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
