[OpenLayers-Users] initialisation of style object
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Dec 8 01:31:55 EST 2011
That should have read ${radius} instead of {$radius}.
Best regards,
Bart
> Can you share your code snippet?
> Is the radius available as a feature attribute? In that case you could use
> something like {$radius}.
> Best regards,
> Bart
>> hi list,
>> I am trying to create a new style object.
>> My start up code says
>> var foo = new OpenLayers.Style({pointRadius:10})
>> By the time it gets to the renderer object the style object should
>> include
>> the following value
>> foo.pointRadius=45
>> but in my case it actual reads
>> foo.pointRadius=0
>> I am not using the Stylemap object
>> I had assumed the calling style object with the pointRadius set  like
>> this
>> would have correctly set up the style object.
>> Which api call should I be calling to ensure this transformation
>> happens?
>> Regards
>> Dave
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
