[OpenLayers-Users] Modifyfeature and standalone
Tue Topholm tt at sugee.dk
Fri Dec 9 17:07:04 EST 2011
Hi All
I have a issue with the modifyfeature and standalone.
As I understand it, when you have enabled standalone you need to give
it the feature you want to modify, right?
I have a small script that uses selectFeature to select the feature,
and gives a list of options, and one of them is edit geometry.
Here I pass the feature in selectFeature.
That is fine, I can now move/edit the feature.
But I can also edit all the other features that are in the map, is this right?
When I do a console.log() on med modifyFeature object, it says standalone = true
So am I doing something wrong?
Med venlig hilsen / Kind regards
Tue Topholm
Sugee
Tlf: +45 32 13 32 32
W: http://www.sugee.dk
