[OpenLayers-Users] Re: Modifyfeature and standalone
Tue Topholm
tt at sugee.dk
Sun Dec 11 03:18:21 EST 2011
I did some further testing and it seems it only points that do this, lines and polygons are fine.
Den 09/12/2011 kl. 23.07 skrev Tue Topholm:
> Hi All
> I have a issue with the modifyfeature and standalone.
> As I understand it, when you have enabled standalone you need to give
> it the feature you want to modify, right?
> I have a small script that uses selectFeature to select the feature,
> and gives a list of options, and one of them is edit geometry.
> Here I pass the feature in selectFeature.
> That is fine, I can now move/edit the feature.
> But I can also edit all the other features that are in the map, is this right?
> When I do a console.log() on med modifyFeature object, it says standalone = true
> So am I doing something wrong?
> Med venlig hilsen / Kind regards
> Tue Topholm
> Sugee
> Tlf: +45 32 13 32 32
> W: http://www.sugee.dk
