[OpenLayers-Users] Multi User edit on same Map
Toby Reinicke
ramotswa at gmail.com
Thu Dec 22 13:53:41 EST 2011
Set up a geoserver instance on your local network, create an openlayers map with osm background and a Wfs layer which is the vehicle layer. Allow editing (lookup Wfs editing in the openlayers examples page) and tell all your workers to look at that page.
This will do what you ask, however the only problem you have is that openstreemap is only available with an Internet connection. So you should serve some basic mapping from your geoserver as a backup.
Toby
On 22 Dec 2011, at 18:42, razibu <backenklatscher at yahoo.de> wrote:
> Hej,
> my Project:
> You have a local area network via ethernet. 3-5 computers in there. This
> place does not always has access to the internet.
> You want to set up a software, that provides openstreetmapdata with layers
> for all the people within the network so they can see the same map and can
> make changes at it.
> So imagine you sittin there an viewing at the map. There is a layer with a
> vehicle at a concret position. Now only you get the information the position
> changed. So you move the vehicle on the map. What should happen now is that
> the other users also see this change on their map.
> Does anybody tried to set up anything same like this?
> multiuser edit with autorefresh
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Multi-User-edit-on-same-Map-tp7119603p7119603.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
