[OpenLayers-Users] Anchor popup on mouse click location?
Alexander Petkov
greenkov at gmail.com
Fri Feb 11 21:05:18 EST 2011
I'd follow this example to get map coordinates from a mouse click on the map:
http://openlayers.org/dev/examples/click.html
Then, you can do
popupFeature = new OpenLayers.Feature(someLayer, latlon);
popupFeature.popupClass = OpenLayers.Popup.FramedCloud;
popupFeature.data.popupContentHTML= "some html here";
cloudPopup = popupFeature.createPopup(true);
map.addPopup(cloudPopup);
cloudPopup.show();
Hope this helps,
Alex
On Fri, Feb 11, 2011 at 12:41 PM, jfranklin <jfranklin at hmgeo.com> wrote:
> I currently have a vector layer (polylines via WFS/geoserver),
> representing trails for a map I'm currently working on.
> I'm using popups to display feature information. That part is working
> fine, and I can have various attributes about the trail in question
> displayed in the popup correctly.
> However, the anchoring seems wiggy. It seems that the popup is
> anchoring to the center of the polyline feature. That's fine for short
> lines, but with long ones weird results occur, such as the map extremely
> far away from the current view.
> So is there any way to anchor the popup to the location where the mouse
> was clicked? Code in question is below...
> // trails vector layer
> var trails = new OpenLayers.Layer.Vector("Trails", {
> styleMap: style_trail,
> projection: new OpenLayers.Projection("EPSG:4326"),
> strategies: [new OpenLayers.Strategy.BBOX()],
> protocol: new OpenLayers.Protocol.WFS({
> url: "http://example.com:8080/geoserver/wfs",
> srsName: "EPSG:4326",
> featureType: "psicc_nfs_trails",
> extractAttributes:true,
> featureNS: "pb_trails"
> //popup code
> var selectControl = new
> OpenLayers.Control.SelectFeature(trails,{onSelect: onFeatureSelect,
> onUnselect: onFeatureUnselect});
> map.addControl(selectControl);
> selectControl.activate();
> function onPopupClose(evt) {
> selectControl.unselect(selectedFeature);
> function onFeatureSelect(feature) {
> selectedFeature = feature;
> popup = new OpenLayers.Popup.FramedCloud("trailinfo",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,200),
> "Trail Name: " + feature.attributes.name, null,
> true, onPopupClose);
> feature.popup = popup;
> map.addPopup(popup);
> function onFeatureUnselect(feature) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
