AW: [OpenLayers-Users] Re: why does the vector layer shift when
i zoom or pan the base layer?
Helder Brandão
helder.brandao at gmail.com
Mon Feb 14 09:59:27 EST 2011
Hi!
Thank you of your response. I read the documentation but the big problem is
the vector layer because the vector layer shift when i pan or zoom.
I want to work only with EPSG:4326 projection without do a projection
tansformation (EPSG:900913 -> EPSG:4326).
If i put sphericalMercator to true i must transform all my coordinates
Best Regards
HB
View this message in context: http://osgeo-org.1803224.n2.nabble.com/why-does-the-vector-layer-shift-when-i-zoom-or-pan-the-base-layer-tp4762297p6023832.html
