[OpenLayers-Users] LayerSwitcher Event
Richard Greenwood richard.greenwood at gmail.com
Fri Feb 18 12:43:01 EST 2011
Answering my own question (which might not be the best answer!) I have
found that the following works:
map.events.register('changelayer', null, function(evt){
       if(evt.property === "visibility") {
          alert(evt.layer.name + " layer visibility changed to " +
evt.layer.visibility );
Regards,
Rich
On Fri, Feb 18, 2011 at 8:34 AM, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> Hello All -
> I am trying to implement a layer change event as Eric Lemoine
> describes below. At the end of my page initialization function I have
> placed the code:
> map.on({
>   "changelayer": function(e) {
>       if(e.property === "visibility") {
>           alert("visibility changed (" + e.layer.name + ")");
> But when the page is loaded I get the error:
>  map.on is not a function
> Am I not registering the event correctly, or can someone see what I am
> doing worng?
> Thanks,
> Rich
> On Thu, Jun 10, 2010 at 4:57 AM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
>> On Thu, Jun 10, 2010 at 11:59 AM, Rahn Hanno (rahn) <rahn at zhaw.ch> wrote:
>>> Hello,
>>> Today I try to realise a "trigger" for my LayerSwitcher. Something like
>>> "onLayerClick" or so.
>>> I want to start a function if I select/unselect a layer in the
>>> Layerswitcher. In my Layerswitcher I have a Layer. If I select this Layer,
>>> then I want to set the opacity from all other layers to 50%. If I unselect
>>> the Layer the opacity should change again to not transparent.
>>> I think I need a trigger function for that layer. If I select some Layer I
>>> would fire a function. I think it would be possible, but I don't know how to
>>> realise.
>>> Perhaps somebody can help me. Or is there something like this already in
>>> OpenLayers what I have not found?
>> Two options:
>> - register a "changelayer" listener on the map
>> map.on({
>> - register a "visibilitychanged" listener on a specific layer
>> layer.on({
>>    "visibilitychanged": function() {
>>        alert"visibility changed (" + layer.name + ")");
>> Hope it helps,
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Richard Greenwood
> www.greenwoodmap.com
Richard Greenwood
