[OpenLayers-Users] LayerSwitcher Event
Richard Greenwood
richard.greenwood at gmail.com
Fri Feb 18 10:34:39 EST 2011
Hello All -
I am trying to implement a layer change event as Eric Lemoine
describes below. At the end of my page initialization function I have
placed the code:
map.on({
"changelayer": function(e) {
if(e.property === "visibility") {
alert("visibility changed (" + e.layer.name + ")");
But when the page is loaded I get the error:
map.on is not a function
Am I not registering the event correctly, or can someone see what I am
doing worng?
Thanks,
Rich
On Thu, Jun 10, 2010 at 4:57 AM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Thu, Jun 10, 2010 at 11:59 AM, Rahn Hanno (rahn) <rahn at zhaw.ch> wrote:
>> Hello,
>> Today I try to realise a "trigger" for my LayerSwitcher. Something like
>> "onLayerClick" or so.
>> I want to start a function if I select/unselect a layer in the
>> Layerswitcher. In my Layerswitcher I have a Layer. If I select this Layer,
>> then I want to set the opacity from all other layers to 50%. If I unselect
>> the Layer the opacity should change again to not transparent.
>> I think I need a trigger function for that layer. If I select some Layer I
>> would fire a function. I think it would be possible, but I don't know how to
>> realise.
>> Perhaps somebody can help me. Or is there something like this already in
>> OpenLayers what I have not found?
> Two options:
> - register a "changelayer" listener on the map
> map.on({
> - register a "visibilitychanged" listener on a specific layer
> layer.on({
> "visibilitychanged": function() {
> alert"visibility changed (" + layer.name + ")");
> Hope it helps,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Richard Greenwood
www.greenwoodmap.com
