AW: [OpenLayers-Users] How to show Lat Long values as a point layer
Armand Turpel aturpel at mnhn.lu
Sun Feb 20 08:00:18 EST 2011
David,
Try to group the results. I'm working on a project for species
observation. It can handle millions of point observations in a small
geographic area. This works only because the results are grouped by
species. No need for geoserver.
Here the test website:
http://test.geocontexter.net/Project_SpeciesObservations_Index/index/id_project/1000000000000002#none
On 19/02/2011 15:21, Arnd Wippermann wrote:
> You should use geoserver to serve your data as WMS (perhaps WFS).
> A web application is not a desktop gis. To show 500-1000 points might be ok,
> but 6000 points from an external vectorfile means a long loading time and
> map navigation will be poorly.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von davidraja.d
> Gesendet: Freitag, 18. Februar 2011 12:09
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] How to show Lat Long values as a point layer
> Hi Friends,
>     I have more than 6000 Lat Long values.Is there any way to show those
> points over the google map.
>   I am using geoserver to project some other layers.I am using oracle spatial
> data base also.
> Thanks in Advance.
> Thanks&  Regards,
> David.
> http://osgeo-org.1803224.n2.nabble.com/How-to-show-Lat-Long-values-as-a-poin
> t-layer-tp6039539p6039539.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Scanned by MailMarshal - Marshal's comprehensive email content security solution.
