[OpenLayers-Users] Permalink in mobile-device-version
Bart van den Eijnden bartvde at osgis.nl
Mon Jul 4 02:26:45 EDT 2011
Please build your own version of OpenLayers.js, do not use the full one.
You can use mobile.cfg and add Permalink to it.
http://docs.openlayers.org/library/deploying.html
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Jul 4, 2011, at 3:00 AM, Noli Sicad wrote:
> Hi Jan,
> Control.Permalink is not present in OpenLayers.mobile.js. Search it in the file.
> Use OpenLayers.js instead, it also contains TouchNavigation control.
> I am using OpenLayers.js in my embedded OpenLayers projects in iPad /
> iPhone with Xcode . I even managed change MousePosition to
> TouchPosition control.
> Noli
> On 7/4/11, Jan Tappenbeck <osm at tappenbeck.net> wrote:
>>  hi !
>> i try to add the permalink-controll into a ol-version for mobile-devices.
>> the base source is from http://www.openlayers.org/dev/examples/mobile.html
>> and my version you found at
>> http://www.tappenbeck.net/osm/olmobile/deu/mobile.html
>> but i get following message into firebug.
>> OpenLayers.Control.Permalink is not a constructor
>>  new OpenLayers.Control.Permalink(),
>> is it not able to use permalink into mobile-device ??
>> regards Jan :-)
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
