[OpenLayers-Users] Zooming to center of a KML layer after
loadingit - request for assistance
Andres Deparis
andres.deparis at gmail.com
Thu Jul 7 21:15:32 EDT 2011
Hello Arnd,
Thank you it works!
As for your question: by the way, does your styleMap work for the kml layer,
if you set extractStyles to true?
I did not bother looking into it now, at first glance it does not. But, I
will surely update you when I get to that in a week or so.
Thank you again. I will update you soon.
Regards.
Andres D.P.
On Fri, Jul 8, 2011 at 1:58 AM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
> Hi,
> register "loadend" for your layer:
> MyKML .events.register("loadend", MyKML , function (e) {
> map.zoomToExtent(MyKML .getDataExtent());
> by the way, does your styleMap work for the kml layer, if you set
> Arnd
> *Von:* openlayers-users-bounces at lists.osgeo.org [mailto:
> openlayers-users-bounces at lists.osgeo.org] *Im Auftrag von *Andres Deparis
> *Gesendet:* Donnerstag, 7. Juli 2011 08:31
> *An:* openlayers-users at lists.osgeo.org
> *Betreff:* [OpenLayers-Users] Zooming to center of a KML layer after
> Hello everyone,
> I am trying to be able to zoom or Pan (zooming first) to the center of the
> data from my kml file that I load periodically. But, in my case, I can load
> the data (which consist of one point at this moment) and then of course to
> be able to center to that point. I have searched and found out that perhaps
> my method does not work because I am zooming into the data but not waiting
> for the data to be fully loaded.
> Below is my piece of code. Thank you in advance for the advice.
> Andres D.P
> var map;
> function init() {
> map = new OpenLayers.Map({
> div: "map",
> //projection: new OpenLayers.Projection("EPSG:900913"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(
> 119.715815, -0.771406, 97.637881 ,7.640186
> ,panDuration: 250 });
> styleMap = new OpenLayers.StyleMap({'default':{
> //label : "${th}",
> label : "MYdog",
> fontColor: "${fontColor}",
> fontSize: "16px",
> labelAlign: "${labelAlign}",
> pointRadius: 2,
> labelXOffset : 0,
> labelYOffset : 20
> var osm = new OpenLayers.Layer.OSM();
> //var vlayer = new OpenLayers.Layer.Vector( "Editable" );
> var MyKML = new OpenLayers.Layer.GML("KML", "dog.kml",
> projection: new OpenLayers.Projection("EPSG:4326"),
> //displayProjection: new
> format: OpenLayers.Format.KML,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true,
> maxDepth: 1
> styleMap: styleMap
> map.addLayers([osm, MyKML]);
> map.addControl(new OpenLayers.Control.PanZoomBar());
> map.addControl(new OpenLayers.Control.Navigation({dragPanOptions:
> {enableKinetic: true}}));
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> // map.addControl(new OpenLayers.Control.MouseToolbar());
> // map.addControl(new OpenLayers.Control.Navigation());
> // map.addControl(new OpenLayers.Control.LayerSwitcher());
> // map.addControl(new OpenLayers.Control.PanZoom());
> // map.addControl(new OpenLayers.Control.EditingToolbar();
> // map.addControl(OpenLayers.Control.EditingToolbar(vlayer));
> map.setCenter(new OpenLayers.LonLat(101.587411,
> 3.021547).transform(new OpenLayers.Projection ("EPSG:4326"),
> map.getProjectionObject()
> 15);
> //map.zoomToExtent( MyKML.GetExtent() );
> window.setInterval(raingaugeRefreshData, 10000, MyKML);
> function raingaugeRefreshData(layer)
> //setting loaded to false unloads the layer//
> layer.loaded = false;
> //setting visibility to true forces a reload of the layer//
> layer.setVisibility(true);
> //the refresh will force it to get the new KML data//
> layer.setUrl('MyDOG.kml?_salt='+Math.random());
> //- <3 from Thqr -//
> map.zoomToExtent( MyKML.maxExtent );
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110708/5cc13db3/attachment-0001.html
