[OpenLayers-Users] VML renderer to do labels as divs not VML rect + textbox
Janis Elmeris janis.elmeris at intelligentsystems.lv
Thu Jul 28 08:51:09 EDT 2011
Hello!
I'm adding Geometry.Points to the map with "label" property in order to
display numbers. However, my IE7 cannot deal with more than 100-200 such
numbers without slowing down considerably and eventually crashing
(whereas FF can do all right even with 3000: using both SVG or Canvas
renderer).
How hard would it be to make the VML renderer to do these label points
as "div" elements? Currently they are rendered as VML "textbox" within
"rect", which IE apparently process slowly. "div" elements would surely
be faster, right?
I tried to simply replace the "rect" and "textbox" in "drawText" to
"div" and "span", but that didn't work: the numbers were positioned
oddly while moving the map. In the original VML renderer it seems that
"rect" is not changed while moving the map (and I cannot understand why
these "rect" are needed at all), but "textbox" changes its margins. I
cannot find what is changing them though.
Regards,
Janis
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110728/4b1b0aff/attachment.html
