[OpenLayers-Users] populate vector layer from json response
Sveen Atle Frenvik (Geomatikk IKT)
Atle.Frenvik.Sveen at geomatikk.no
Tue Jun 21 03:37:15 EDT 2011
try using an OpenLayers.Geometry.Point instead of an OpenLayers.LonLat
ie (untested, but i think this is rather correct):
function parseTweetsQ(){
if (tweetsQ.length > 0) {
var tweet = tweetsQ.pop();
if (tweet.geo){
tweet.point = new OpenLayers.Geometry.Point(tweet.geo.coordinates[0],tweet.geo.coordinates[1]).transform(new OpenLayers.Projection("EPSG:4326"),map.getProjectionObject());
tweet.attributes = {}; //in this you coukd stuff attributes of the tweet for easy access on clicks etc.
plotTwt(tweet);
function plotTwt(tweet){
//why do you keep adding the layer for each tweet?
map.addLayer(tweetz);
tweet.marker = new OpenLayers.Feature.Vector(tweet.point,{attributes:{tweet.attributes]});
tweetz.addFeatures([tweet.marker]);
On 2011-06-21 05:00, Nicholas Efremov-Kendall wrote:
Hi Phil et al,
Thanks for your response. The code as is does iterate through the features as they are returned. I have a handle on it up to the plotting function. An alert on the tweet.marker object returns [object Object], while tweet.latlng returns readable coordinates lon=38.6834,lat=-90.4313. I guess what I'm unsure about is how to parse the object which is passed to the third function. Thanks again.
function acquireTweets(){
$.getJSON(createTWTsrcURL(), function(data){
if(data.results)
$.each(data.results, function(i, tweet){
if (tweet.geo || tweet.location)
tweetsQ.push(tweet);
refreshQuery = data.refresh_url;
if (tweet.geo){
tweet.latlng = new OpenLayers.LonLat(tweet.geo.coordinates[0],tweet.geo.coordinates[1]);
plotTwt(tweet);
tweet.marker = new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(tweet.latlng).transform(new OpenLayers.Projection("EPSG:4326"),map.getProjectionObject()));
tweetz.addFeatures([tweet.marker]);}
On Mon, Jun 20, 2011 at 9:13 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
I have no idea what the object returned by twitter is but surely, but if
you are using jsonp, then
have in your code something like:
jsonp_function(json)
where jsonp_function is the name of jsonp callback and json is the
returned object. I would guess it contains an array of feature type
objects, so you would iterate through the array, creating feature for
each row, and calling vectorLayer.addFeatures(features) to add them to
the vector layer.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Users mailing list
Atle Frenvik Sveen
Utvikler
Geomatikk IKT AS
tlf: 45 27 86 89
atle.frenvik.sveen at geomatikk.no
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110621/7e6420bb/attachment.html
