[OpenLayers-Users] Re: Can't get WFS to work.
sulu
andreas.siegel at vorarlberg.at
Fri Jun 24 06:29:08 EDT 2011
Hi Casper,
thanks for answering.
Are you referring to the proxy.cgi script?
It works well in my case.
mapserver and Openlayers reside on the same physical machine so i doubt i
have proxy issues.
My problem is that nothing gets rendered on the screen.
If one is interested to try the WFS-Service please use:
http://vogis.cnv.at/mapserver/mapserv?map=wfs_test.map&service=wfs&request=getcapabilities
In OL i use that code to glue the WFS-layer into my map:
> var wfs = new OpenLayers.Layer.Vector("FWP-KG", {
> strategies: [new OpenLayers.Strategy.BBOX()],
> protocol: new OpenLayers.Protocol.WFS({
> url:
> "http://cnvbrwgdit2.net.vlr.gv.at/cgi-bin/mapserv?map=wfs_test.map",
> featureType: "kg-grenze",
> featureNS: "http://www.openplans.org/topp"
> map.addLayers([layer, wfs]);
If i call my OL-HTML in Firefox, Firebug shows something like:
> http://cnvbrwgdit2.net.vlr.gv.at/cgi-bin/proxy.cgi?url=http://cnvbrwgdit2.net.vlr.gv.at/cgi-bin/mapserv?map=wfs_test.map&<wfs:GetFeature
> xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Query
> typeName="feature:kg-grenze"
> xmlns:feature="http://www.openplans.org/topp"><ogc:Filter
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>the_geom</ogc:PropertyName><gml:Box
> xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:31254"><gml:coordinates decimal="." cs="," ts="
> ">-195000,112500
> 125000,352500</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter></wfs:Query></wfs:GetFeature>
So there is some WFS-activity going on.
Mapserver returns some XML-Code like:
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://cnvbrwgdit2.net.vlr.gv.at/mapserver/mapserv?map=wfs_test.map&version=1.1.1&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=feature:kg-grenze&OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:31254">
> <gml:coordinates>-60708.899987,189112.439997
> -7238.329998,273190.070001</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <gml:featureMember>
> <ms:kg-grenze>
> <gml:boundedBy>
> <gml:coordinates>-39201.779996,230833.604001
> -34718.157992,236709.662996</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <ms:msGeometry>
> <gml:Polygon srsName="EPSG:31254">
> <gml:outerBoundaryIs>
> <gml:LinearRing>
> <gml:coordinates>-36482.179000,236674.556996
> -36470.541992,236673.196001 -36386.308992,236684.556000
> -36373.859996,236672.739997 -36367.460000,236675.189999
> -36680.108992,236608.511999 -36566.858997,236703.756996
> -36560.639997,236709.662996
> -36556.016992,236706.866002 -36549.283998,236698.247998
> -36482.179000,236674.556996 </gml:coordinates>
> </gml:LinearRing>
> </gml:outerBoundaryIs>
> </gml:Polygon>
> </ms:msGeometry>
> </ms:kg-grenze>
> </gml:featureMember>
> <gml:featureMember>
> <ms:kg-grenze>
> <gml:boundedBy>
> <gml:coordinates>-40245.269997,220756.769998
> -31109.289998,226623.864000</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <ms:msGeometry>
> </quote>
> This seems a sensible replay from mapserver. But, as i said, nothing
> visual happens.
> Cheers
> Andy
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Casper Span wrote:
> Hi,
> I think you are running against a problem I had as well: the lack of a
> proxy
> / proxy script.
> You can only get WFS data again the same domain. (and thus, the same port
> as
> well)
> So if you're MapServer isn't running on the same domain as your OL page,
> you
> will need a forwarder from the OL code to the Mapserver.
> Something like http://yourwebsite.com/mapserver -->
> http://yourmapserver.com/mapserver
> or http://yourwebsite.com:8080/mapserver -->
> Hope this helps!
> regards,
> Casper
> On Wed, Jun 22, 2011 at 3:48 PM, sulu <andreas.siegel at vorarlberg.at>
> wrote:
>> Hi.
>> Yes, i know this topic is far from new but i'm stuck getting my
>> OL-WFS-Test-Client to work.
>> The basic idea it to get the background from a Mapserver-WMS-Service and
>> plot on this some vector-data from a WFS-Layer (also provided by
>> mapserver).
>> WMS works pretty well but WFS won`t.
>> Before i flood this post with code-samples of my mapfiles and/or the
>> OL-HTML-document i would like to ask if there is a walkthrough where it
>> is
>> shown how to code a correct mapfile and the corresponding OL-Code.
>> Or if one could provide me with a working wfs-mapfile and a matching
>> OL-Code
>> i would be very grateful.
>> Thanks in advance
>> Andy
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Can-t-get-WFS-to-work-tp6504309p6504309.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
Casper Span wrote:
> Hi,
> proxy
> / proxy script.
> as
> well)
> you
> Hope this helps!
> regards,
> Casper
> wrote:
>> Hi.
>> mapserver).
>> is
>> OL-Code
>> Thanks in advance
>> Andy
>> Users mailing list
> Users mailing list
Casper Span wrote:
> Hi,
> proxy
> / proxy script.
> as
> well)
> you
> Hope this helps!
> regards,
> Casper
> wrote:
>> Hi.
>> mapserver).
>> is
>> OL-Code
>> Thanks in advance
>> Andy
>> Users mailing list
> Users mailing list
Casper Span wrote:
> Hi,
> proxy
> / proxy script.
> as
> well)
> you
> Hope this helps!
> regards,
> Casper
> wrote:
>> Hi.
>> mapserver).
>> is
>> OL-Code
>> Thanks in advance
>> Andy
>> Users mailing list
> Users mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-get-WFS-to-work-tp6504309p6511514.html
