[OpenLayers-Users]
OpenLayers.Projection(OpenLayers.Util.getElement(......).value) -
jQuery problem
Noli Sicad
nsicad at gmail.com
Fri Jun 24 20:23:06 EDT 2011
I am having problem executing this updateFormats function (below)
which contains (OpenLayers.Util.getElement(......).value) in my jQuery
mobile OL. The updateFormats is demonstrated in vector formats, in
projection and out projection. My select controls are getting back
when I clicked it.
http://openlayers.org/dev/examples/vector-formats.html
It seems that the problem is probably in the
OpenLayers.Util.getElement(......) which a $.
In Util.js,
OpenLayers.Util.isElement = function(o) {
return !!(o && o.nodeType === 1);
* Maintain existing definition of $.
if(typeof window.$ === "undefined") {
window.$ = OpenLayers.Util.getElement;
Is this intervening in jQuery? Could I delete this? What would be the
solution inorder that updateFormats will be executed properly?
Thanks in advance.
Regards, Noli
This updateFormats in jQuery.
$(function() {
function updateFormats() {
alert("updated!");
var in_options = {
'internalProjection': map.baseLayer.projection,
'externalProjection': new
OpenLayers.Projection(OpenLayers.Util.getElement("inproj").value)
alert(in_options);
var out_options = {
OpenLayers.Projection(OpenLayers.Util.getElement("outproj").value)
var gmlOptions = {
featureType: "feature",
featureNS: "http://example.com/feature"
var gmlOptionsIn = OpenLayers.Util.extend(
OpenLayers.Util.extend({}, gmlOptions),
in_options
var gmlOptionsOut = OpenLayers.Util.extend(
out_options
var kmlOptionsIn = OpenLayers.Util.extend(
{extractStyles: true}, in_options);
formats = {
'in': {
wkt: new OpenLayers.Format.WKT(in_options),
geojson: new OpenLayers.Format.GeoJSON(in_options),
gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
kml: new OpenLayers.Format.KML(kmlOptionsIn)
'out': {
wkt: new OpenLayers.Format.WKT(out_options),
geojson: new OpenLayers.Format.GeoJSON(out_options),
gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
kml: new OpenLayers.Format.KML(out_options)
$('#inproj, #outproj').change(updateFormats);
}); // for the function
