[OpenLayers-Users]
OpenLayers.Projection(OpenLayers.Util.getElement(......).value)
- jQuery problem
Nick Kendall
n.e.kendall at gmail.com
Fri Jun 24 22:24:19 EDT 2011
Try the jquery no conflict function
http://docs.jquery.com/Using_jQuery_with_Other_Libraries
Sent from my mobile device
On Jun 24, 2011, at 8:23 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> I am having problem executing this updateFormats function (below)
> which contains (OpenLayers.Util.getElement(......).value) in my jQuery
> mobile OL. The updateFormats is demonstrated in vector formats, in
> projection and out projection. My select controls are getting back
> when I clicked it.
> http://openlayers.org/dev/examples/vector-formats.html
> It seems that the problem is probably in the
> OpenLayers.Util.getElement(......) which a $.
> In Util.js,
> OpenLayers.Util.isElement = function(o) {
> return !!(o && o.nodeType === 1);
> * Maintain existing definition of $.
> if(typeof window.$ === "undefined") {
> window.$ = OpenLayers.Util.getElement;
> Is this intervening in jQuery? Could I delete this? What would be the
> solution inorder that updateFormats will be executed properly?
> Thanks in advance.
> Regards, Noli
> This updateFormats in jQuery.
> $(function() {
> function updateFormats() {
> alert("updated!");
> var in_options = {
> 'internalProjection': map.baseLayer.projection,
> 'externalProjection': new
> OpenLayers.Projection(OpenLayers.Util.getElement("inproj").value)
> alert(in_options);
> var out_options = {
> OpenLayers.Projection(OpenLayers.Util.getElement("outproj").value)
> var gmlOptions = {
> featureType: "feature",
> featureNS: "http://example.com/feature"
> var gmlOptionsIn = OpenLayers.Util.extend(
> OpenLayers.Util.extend({}, gmlOptions),
> in_options
> var gmlOptionsOut = OpenLayers.Util.extend(
> out_options
> var kmlOptionsIn = OpenLayers.Util.extend(
> {extractStyles: true}, in_options);
> formats = {
> 'in': {
> wkt: new OpenLayers.Format.WKT(in_options),
> geojson: new OpenLayers.Format.GeoJSON(in_options),
> gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
> gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
> kml: new OpenLayers.Format.KML(kmlOptionsIn)
> 'out': {
> wkt: new OpenLayers.Format.WKT(out_options),
> geojson: new OpenLayers.Format.GeoJSON(out_options),
> gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
> gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
> kml: new OpenLayers.Format.KML(out_options)
> $('#inproj, #outproj').change(updateFormats);
> }); // for the function
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
