R: [OpenLayers-Users] OpenLayers and WMS (EPSG:3004)
Severini Cristiano
Cristiano.Severini at aceaspa.it
Tue Jun 28 11:36:38 EDT 2011
ok, so my WMS needs to expose data/images in EPSG:900913, right?
-----Messaggio originale-----
Da: Bart van den Eijnden [mailto:bartvde at osgis.nl]
Inviato: mar 28/06/2011 15.49
A: Severini Cristiano
Cc: openlayers-users at lists.osgeo.org
Oggetto: Re: [OpenLayers-Users] OpenLayers and WMS (EPSG:3004)
OpenLayers can not reproject images.
So you need to use the Google Mercator projection for your WMS layer, so that your WMS reprojects instead.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Jun 28, 2011, at 3:32 PM, Severini Cristiano wrote:
> Hi,
> i'm trying to overlay my own WMS service on Google/OpenStreetMap but i'm getting problems.
> I set EPSG:3004 with Proj4js and works (I can see correct mouse's coords)
> var options = {
> controls:[],
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:3004")
> map = new OpenLayers.Map('map', options);
> osm = new OpenLayers.Layer.OSM("Open Street Map");
> map.addLayer(osm);
> lines = new OpenLayers.Layer.WMS("MY LAYER",
> "http://myserver/wms/service.asp",
> layers: 'lines',
> transparent: 'true'
> singleTile: true,
> units: 'meters',
> projection: new OpenLayers.Projection("EPSG:3004"),
> map.addLayer(lines);
> My lines are displayed over Greece.
> I guess the issue is on the request. The requests is done with SRS and BBOX in EPSG:900913
> Any solution?
> TIA
> crino
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110628/12fd1233/attachment-0001.html
