[OpenLayers-Users] OpenLayers and WMS (EPSG:3004)
    Bart van den Eijnden
    bartvde at osgis.nl
    Tue Jun 28 09:49:19 EDT 2011
OpenLayers can not reproject images.
So you need to use the Google Mercator projection for your WMS layer, so that your WMS reprojects instead.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Jun 28, 2011, at 3:32 PM, Severini Cristiano wrote:
> Hi,
> i’m trying to overlay my own WMS service on Google/OpenStreetMap but i’m getting problems.
> I set EPSG:3004 with Proj4js and works (I can see correct mouse’s coords)
> var options = {
>    controls:[],
>    projection: new OpenLayers.Projection("EPSG:900913"),
>    displayProjection: new OpenLayers.Projection("EPSG:3004")
> map = new OpenLayers.Map('map', options);
> osm  = new OpenLayers.Layer.OSM("Open Street Map");
> map.addLayer(osm);
> lines = new OpenLayers.Layer.WMS("MY LAYER",
>    "http://myserver/wms/service.asp",
>       layers: 'lines',
>       transparent: 'true'
>       singleTile: true,
>       units: 'meters',
>       projection: new OpenLayers.Projection("EPSG:3004"),
> map.addLayer(lines);
> My lines are displayed over Greece.
> I guess the issue is on the request. The requests is done with SRS and BBOX in EPSG:900913
> Any solution?
> TIA
> crino
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110628/9528c2e2/attachment.html
