[OpenLayers-Users] Re: Why WFS Layer is displaying very slowely over Google Map.
Ravi Pavuluri ravitheja at ymail.com
Fri Mar 4 10:42:10 EST 2011
I would initially suggest what Phil and Alexandre mentioned earlier(going with
WMS initially for showing the features and wfs for getting the features). In
your case, the click doesn't come from map.
If you have a database serving your data, you can run Ajax call to the
database(use your server side language) and fetch the primary key you wanted
from the database based on entered text. Then you can run a WFS call to retrieve
the geometry for that feature based on primary key you fetched.
-Ravi.
To: users at openlayers.org
Sent: Fri, March 4, 2011 10:26:27 AM
Subject: [OpenLayers-Users] Re: Why WFS Layer is displaying very slowely over
Google Map.
I am not going to click on feature to get feature's info. I need a different
scenario.
In my case, The requirement is to highlight a specific feature under Button
click event.  Actually I have a Button and Textbox. The user puts some value
in textbox and press the button, Under Button click event, Textbox value
needs to compare with specific column value  of all the features (3500
features) in loop. And finally, one feature will be selected based on
comparision.
so, for this reason, i need all the features displayed over google map
before performing the above action. Now, Please guide me How I can draw
Vector Layer fastly. OR is there any other way to solve this problem?
Regards
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Why-WFS-Layer-is-displaying-very-slowely-over-Google-Map-tp6085290p6088848.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110304/1cfaae1f/attachment.html
