[OpenLayers-Users] Re: FramedCloud Offset Issue
Peter Osm
peter.osm at gmx.net
Fri Mar 11 09:00:19 EST 2011
On 09.03.2011 15:18, wrote Colin Kirkham:
Hi
> I have an example (below) where I add a new marker (specified manually
> not via a feature layer). When I add a popup using the marker's icon
> as an anchor I'm finding it doesn't line up and I can't figure out
> what the issue is.
Hit that a day ago too, wrote a minimal example that shows
the problem, could have saved some hours if i read this
list before:-)
> I know that I can specify an anchor by providing my own object
> implementing size and offset,
You proved that this really fixes the problem?
So i could have a workaround.
> but I'd expect this to work so I'm just
> keen to find out what the issue is.
> Any help would be appreciated.
'Shurely' a bug:
<http://trac.osgeo.org/openlayers/ticket/3168>
with a merge of your example and mine.
Peter
