[OpenLayers-Users] problem with geolocation
Bart van den Eijnden
bartvde at osgis.nl
Sat Mar 12 14:59:49 EST 2011
This is not available in 2.10 only in trunk and the upcoming 2.11 release.
Bart
Sent from my iPhone
On Mar 12, 2011, at 11:56 AM, Nicholas Efremov-Kendall <n.e.kendall at gmail.com> wrote:
> Hi Everyone,
> I apologize in advance for what I assume is a pretty trivial error. I've been trying to implement the geolocation example on my local system, but I get an error "ol.control.geolocate is not a constructor" in Firebug, and uncaught typeerror: undefined is not a function in chrome. I've tried this both with linking the OL script to the live api url, as well as to a local copy of OL 2.10. I repost the code below, but I just copied it from the live example and got this error.
> Thanks in advance!
> var style = {
> fillColor: '#000',
> fillOpacity: 0.1,
> strokeWidth: 0
> var map = new OpenLayers.Map('map');
> var layer = new OpenLayers.Layer.OSM( "Simple OSM Map");
> var vector = new OpenLayers.Layer.Vector('vector');
> map.addLayers([layer, vector]);
> map.setCenter(
> new OpenLayers.LonLat(-71.147, 42.472).transform(
> new OpenLayers.Projection("EPSG:4326"),
> map.getProjectionObject()
> ), 12
> var pulsate = function(feature) {
> var point = feature.geometry.getCentroid(),
> bounds = feature.geometry.getBounds(),
> radius = Math.abs((bounds.right - bounds.left)/2),
> count = 0,
> grow = 'up';
> var resize = function(){
> if (count>16) {
> clearInterval(window.resizeInterval);
> var interval = radius * 0.03;
> var ratio = interval/radius;
> switch(count) {
> case 4:
> case 12:
> grow = 'down'; break;
> case 8:
> grow = 'up'; break;
> if (grow!=='up') {
> ratio = - Math.abs(ratio);
> feature.geometry.resize(1+ratio, point);
> vector.drawFeature(feature);
> count++;
> window.resizeInterval = window.setInterval(resize, 50, point, radius);
> var geolocate = new OpenLayers.Control.Geolocate({
> geolocationOptions: {
> enableHighAccuracy: false,
> maximumAge: 0,
> timeout: 7000
> map.addControl(geolocate);
> geolocate.events.register("locationupdated",this,function(e) {
> vector.removeAllFeatures();
> var circle = new OpenLayers.Feature.Vector(
> OpenLayers.Geometry.Polygon.createRegularPolygon(
> new OpenLayers.Geometry.Point(e.point.x, e.point.y),
> e.position.coords.accuracy/2,
> 40,
> 0
> style
> vector.addFeatures([
> e.point,
> graphicName: 'cross',
> strokeColor: '#f00',
> strokeWidth: 2,
> fillOpacity: 0,
> pointRadius: 10
> circle
> map.zoomToExtent(vector.getDataExtent());
> pulsate(circle);
> geolocate.events.register("locationfailed",this,function() {
> OpenLayers.Console.log('Location detection failed');
> $('locate').onclick = function() {
> geolocate.deactivate();
> $('track').checked = false;
> geolocate.watch = false;
> geolocate.activate();
> $('track').onclick = function() {
> if (this.checked) {
> geolocate.watch = true;
> Dept. of Anthropology
> Washington University in St. Louis
> Campus Box 1114
> St. Louis, MO, 63130
> (917) 370-3489
> nefremov at wustl.edu
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110312/d5b3bd45/attachment.html
