[OpenLayers-Users] Re: Limit of layers for SelectFeature Control?
Planet)x
andrew.stewart at reddeer.ca
Sun Mar 13 14:09:35 EDT 2011
So I have developed a slight work-around for this problem but not sure if
there is a better way to accomplish this. Basically I am recreating the
layer each time one of the layerlist items is checked. I am removing the
Vector layer from my map and then recreating it with an array of featureType
attributes (array of strings I have passed). I then redefine my
selectfeature control with the newly created Vector layer and it works with
all the typenames. Not sure why this happens but I can pass one single
Vector layer made up of many many featureTypes.. yet if I try to pass the
same amount of individual vector layers to the control it stops functioning
after 10 layers, is this supposed to be the case?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Limit-of-layers-for-SelectFeature-Control-tp6166440p6166790.html
