[OpenLayers-Users] Re: OpenLayers.loadUrl is not a function
Kris Peterson kris at mapbiquity.com
Fri Mar 18 14:26:43 EDT 2011
Hi Manuel,
Are any other calls to OpenLayers working or is this the first reference to
the OpenLayers library the code hits? The error suggests that OpenLayers is
not loading properly (maybe an error in the src attribute of the script
tag). Since you're using FireBug you can easily check if this is the case.
If the library is not loading properly, then fixing the library reference
should take care of this for you.
If the library is referenced correctly, we'll need more of your code to be
able to determine the problem. Do you have a live example?
Regards,
Kris
Kris Peterson
www.mapbiquity.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-loadUrl-is-not-a-function-tp6185417p6185641.html
