[OpenLayers-Users] ArcGIS REST services
Jeff Dege jeff.dege at korterra.com
Fri Mar 25 12:22:37 EDT 2011
When I view that page in IE8, it doesn't work at all:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.6; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; InfoPath.3)
Timestamp: Fri, 25 Mar 2011 15:47:29 UTC
Message: Expected identifier, string or number
Line: 145
Char: 21
Code: 0
URI: http://www.openlayers.org/dev/examples/arcgiscache_ags.html
Message: Object expected
Line: 163
Char: 1
Code: 0
It works in Firefox.
Looks like our biggest problems are going to be projections and resolutions - our other layers are not in Spherical Mercator, and we are not currently drawing our maps scales that match the ArcGIS resolutions.
Thanks for the pointer.
-----Original Message-----
From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
Sent: Friday, March 25, 2011 9:31 AM
To: Jeff Dege
Cc: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] ArcGIS REST services
Hi Jeff,
does this work for you?
It's the second layer in the layer switcher.
Best regards,
Bart
> ESRI has published a standard for accessing map data via REST webservices:
> http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2010/09/07/The-Ge
> oServices-REST-Specification_3A00_-An-open-standard-for-GIS-Web-servic
> es.aspx
> They have made a good deal of map data available for non-commercial
> purposes:
> http://services.arcgisonline.com/ArcGIS/rest/services
> This includes a reasonably current world street landbase:
> http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map
> /MapServer
> So now the questions:
> How can I most easily display this landbase as a layer in OpenLayers?
> Does OpenLayers support the GeoServices REST specification?  Is there
> any work in progress to do so?
> Any idea how much work would be involved to add such support to
> OpenLayers?
> If I cannot access GeoServices REST data from OpenLayers, does anyone
> know of an Open Source WMS/WFS server that does/will support
> GeoServices REST data?
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
