[OpenLayers-Users] ArcGIS REST services
Bart van den Eijnden
bartvde at osgis.nl
Fri Mar 25 12:48:31 EDT 2011
Should be fixed in trunk, thanks for the feedback.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Mar 25, 2011, at 5:22 PM, Jeff Dege wrote:
> When I view that page in IE8, it doesn't work at all:
> Webpage error details
> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.6; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; InfoPath.3)
> Timestamp: Fri, 25 Mar 2011 15:47:29 UTC
> Message: Expected identifier, string or number
> Line: 145
> Char: 21
> Code: 0
> URI: http://www.openlayers.org/dev/examples/arcgiscache_ags.html
> Message: Object expected
> Line: 163
> Char: 1
> Code: 0
> It works in Firefox.
> Looks like our biggest problems are going to be projections and resolutions - our other layers are not in Spherical Mercator, and we are not currently drawing our maps scales that match the ArcGIS resolutions.
> Thanks for the pointer.
> -----Original Message-----
> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
> Sent: Friday, March 25, 2011 9:31 AM
> To: Jeff Dege
> Cc: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] ArcGIS REST services
> Hi Jeff,
> does this work for you?
> It's the second layer in the layer switcher.
> Best regards,
> Bart
>> ESRI has published a standard for accessing map data via REST webservices:
>> http://blogs.esri.com/Dev/blogs/arcgisserver/archive/2010/09/07/The-Ge
>> oServices-REST-Specification_3A00_-An-open-standard-for-GIS-Web-servic
>> es.aspx
>> They have made a good deal of map data available for non-commercial
>> purposes:
>> http://services.arcgisonline.com/ArcGIS/rest/services
>> This includes a reasonably current world street landbase:
>> http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map
>> /MapServer
>> So now the questions:
>> How can I most easily display this landbase as a layer in OpenLayers?
>> Does OpenLayers support the GeoServices REST specification? Is there
>> any work in progress to do so?
>> Any idea how much work would be involved to add such support to
>> OpenLayers?
>> If I cannot access GeoServices REST data from OpenLayers, does anyone
>> know of an Open Source WMS/WFS server that does/will support
>> GeoServices REST data?
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
