[OpenLayers-Users] Releasing memory
Andreas Hocevar
ahocevar at opengeo.org
Mon May 2 12:50:54 EDT 2011
Hey,
OpenLayers unloads itself properly when the page unloads (except for
some known memory leaks). If you want to unload a map instance
manually, you should call map.destroy().
Regards,
Andreas.
On Mon, May 2, 2011 at 6:09 PM, Janis Elmeris
<janis.elmeris at intelligentsystems.lv> wrote:
> Hello!
> OpenLayers.Map has three functions that look like being used for freeing
> memory:
> destroy(), unloadDestroy(), updateSizeDestroy().
> Am I supposed to explicitly call them or not? From the description of
> "unloadDestroy", for example, it seems that it is already called by
> something.
> I'm looking something similar to Google Maps' GUnload, which is supposed to
> be run upon page unload event - is there something similar needed for
> OpenLayers?
> Thanks!
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
