[OpenLayers-Users] Releasing memory
Janis Elmeris janis.elmeris at intelligentsystems.lv
Mon May 2 13:19:22 EDT 2011
Thanks!
So if I have one map that is open from the beginning to the end when the
page is closed, I just do nothing in this regard.
What about the known memory leaks, is there some article or discussion
you could point me to?
Janis
On 2011.05.02. 19:50, Andreas Hocevar wrote:
> Hey,
> OpenLayers unloads itself properly when the page unloads (except for
> some known memory leaks). If you want to unload a map instance
> manually, you should call map.destroy().
> Regards,
> Andreas.
> On Mon, May 2, 2011 at 6:09 PM, Janis Elmeris
> <janis.elmeris at intelligentsystems.lv>  wrote:
>> Hello!
>> OpenLayers.Map has three functions that look like being used for freeing
>> memory:
>> destroy(), unloadDestroy(), updateSizeDestroy().
>> Am I supposed to explicitly call them or not? From the description of
>> "unloadDestroy", for example, it seems that it is already called by
>> something.
>> I'm looking something similar to Google Maps' GUnload, which is supposed to
>> be run upon page unload event - is there something similar needed for
>> OpenLayers?
>> Thanks!
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110502/f227ff2a/attachment.html
