[OpenLayers-Users] OpenLayers.Protocol.WFS
Alexandre Dube
adube at mapgears.com
Tue May 3 09:13:06 EDT 2011
Hi Etienne,
My guess is that it might be related to a feature namespace issue.
Look in Firebug, in the Console tab, what is the namespace returned
inside your GML. You can change it in you mapfile by setting the
following in the Map "Metadata" section :
"wfs_namespace_uri" "http://localhost" # example
and set the according ns in OpenLayers :
featureNS: "http://localhost" // example
HTH,
Alexandre
On 11-05-03 08:28 AM, Etienne DELAY wrote:
> Hello,
> I tryto work to display information coming from MapServer as WFS, the
> following code works:
> VectVigneti = new OpenLayers.Layer.WFS("coperture del suolo",
> "http://localhost/cgi-bin/mapserv?map=/home/delaye/vector.map",
> {typename: 'vigneti'},
> { extractAttributes:
> true, visibility: false});
> But I have read on the documentation than that this technique is
> "Deprecated". I try with OpenLayers.Layer.Vecto and protocol: new
> OpenLayers.Protocol.WFS, but that doesn't work. I have not solved my
> problem with the answer to this question on the mailing list
> (http://osgeo-org.1803224.n2.nabble.com/Problem-with-OpenLayers-Protocol-WFS-from-Geoserver-td5167039.html).
> I wanted to know if someone could help me to understand where is my
> problem.
> This is my code :
> var wfs = new OpenLayers.Layer.Vector("vigneti", {
> projection: new OpenLayers.Projection("EPSG:32632"),
> protocol: new OpenLayers.Protocol.WFS({
> url: "http://localhost/cgi-bin/mapserv?map=/home/delaye/vector.map",
> schema:
> "http://localhost/cgi-bin/mapserv?map=/home/delaye/vector.map&SERVICE=WFS&REQUEST=GetSchema&schema=miwfs:vigneti&VERSION=1.0.0
> <http://localhost/cgi-bin/mapserv?map=/home/delaye/vector.map&SERVICE=WFS&REQUEST=GetSchema&schema=miwfs:vigneti&VERSION=1.0.0>",
> //equivalent a layer pour les couche wms
> featureType: "vigneti",
> srsName: "EPSG:32632",
> featureNS: "http://www.openplans.org/topp",
> And firebug gives me no errors ...
> thank you very much
> Cordialement
> Etienne DELAY
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110503/14cbf0dc/attachment-0001.html
