[OpenLayers-Users] Select Multiple Points (within a Polygon) Across
Multiple Polygons
jacobstr
jacobstr at gmail.com
Wed May 4 20:02:53 EDT 2011
I'd like to be able to draw a selection box around multiple polygons on my
map and select the *individual points* within them (rather than the polygons
themselves).
I tried to add: `geometryTypes: ['OpenLayers.Geometry.Point']` to my
OpenLayers.Control.SelectFeature call, but it will only work on Features
who's geometry consists of a point (It won't work with a
Polygon->LinearRing->Point type of hierarchy).
In particular, the feature I'm trying to build is:
1. Select multiple points on a map.
2. Allow the user to "merge" the two points - their x and y coords will be
averaged and both points will be moved to this averaged location.
I'm currently hacking away at my own version of this:
http://opengeo.org/technology/openlayers/coredevelopment/tool_sharedboundsedit/
Right now my feeling is I would have to extend the SelectFeature control -
which is what I had to do with DragFeature to enable dragging "shared"
vertices simultaneously.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Select-Multiple-Points-within-a-Polygon-Across-Multiple-Polygons-tp6332772p6332772.html
