[OpenLayers-Users] Re: Max size KML description content
Peter Peterse
peter at peterse-uithuizen.com
Fri May 6 04:06:51 EDT 2011
Hello Rossco,
thanks for your support. I will look to improve the KML to be validate
correcly.
But if I insert the html tags in the description than the size of the
content will only be bigger.
Firefox cuts off more than 1500 characters. When You click on the item in
the middle of the map a javascript alert will give you the lenght of the
content. Firefox give 4096 (very nice value 4*1024!!) IE gives 5671
characters (the complete set)
Regards,
Peter
>> http://osm.peterse-uithuizen.com/~peter/info.kml
> Your KML doesn't validate nicely
> http://kmlvalidator.com/validate.htm
> I think the issue you can see is due to including <html> <head> <body> etc
> tags in your <description> content, different browsers will handle trying
> to
> insert this into an existing page differently
> http://osgeo-org.1803224.n2.nabble.com/Max-size-KML-description-content-tp6335275p6336035.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
