[OpenLayers-Users] Re: Max size KML description content
Rossko
rossko at culzean.clara.co.uk
Tue May 10 05:05:56 EDT 2011
> But if I insert the html tags in the description than the size of the
> content will only be bigger.
You may have missed my point ; your map is displayed in a webpage wrapped in
<html></html> tags. It will upset the browser if you invalidly put more
<html>content</html> tags in the middle of the page ; it is not allowed.
Different browsers will get upset in different ways.
Your KML <description> includes <html>content</html>, so when this is
displayed on your page it wil be invalid. Results are unpredictable.
Make your <description> into HTML snippets that remain valid when added to
an existing page ; remove <html>,<head>,<body> tags.
It may or may not fix your problem, but no-one will want to look into your
problem if you are starting out with garbage data.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Max-size-KML-description-content-tp6335275p6347114.html
