[OpenLayers-Users] Re: using two Projections?
BMcBride
bmcbride at opengeo.org
Wed May 11 10:26:28 EDT 2011
OpenLayers defaults to EPSG:4326, so if you leave the projection empty in the
map options, your map will be EPSG:4326. You cannot overlay a topo layer
that is in EPSG:4326 onto OSM, which is EPSG:900913. If your topo layer is
a WMS, it may also be available in EPSG:900913. If it is a vector layer, you
could transform from 4326 -> 900913.
Bryan McBride, GISP
OpenGeo - http://opengeo.org
Expert service straight from the developers.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/using-two-Projections-tp6352040p6352071.html
