[OpenLayers-Users] How to capture a mouse-up event?
PixelPusher
pixelpusher at cox.net
Mon May 16 15:48:39 EDT 2011
Alexandre,
Fantastic! That is even better than grabbing the mouseup. Those two events are the things that I thought I'd have to create myself.
Thanks!
---- Alexandre Dube <adube at mapgears.com> wrote:
> Hi,
> FYI, there is no "mouseup" event in the OpenLayers.Map class. You
> could use the "moveend" and/or "zoomend" events. Here's an other way of
> registering events :
> map.events.on({"moveend": function(e) {
> alert("map moveend");
> }, "zoomend": function(e) {
> alert("map zoomend");
> }, scope: map});
> Use firebug to set breakpoints on the "alert" lines to see the value of
> "this" (scope) and "e" (parameter of the callback methods).
> Best regards,
> Alexandre
> On 11-05-16 01:40 PM, Simon Appelt wrote:
> > Hi Tom,
> > maybe something like this should work:
> > map.events.register("mouseup", this, function() { alert("untested")});
> > greetings,
> > Simon Appelt
> > Am 16.05.2011 17:35, schrieb PixelPusher:
> >> I'm trying to figure out how to trigger an event when the user stops
> >> panning and/or zooming. I found the "click" example, but I don't see
> >> that helping me solve the problem. Are there any specific examples
> >> that I should look at to do this?
> >> Thanks!
> >> Thom
> >> Man will occasionally stumble over the truth, but most of the time
> >> he will pick himself up and continue. -- Winston
> >> Churchill
> >> _______________________________________________
> >> Users mailing list
> >> Users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> > Users mailing list
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
he will pick himself up and continue. -- Winston Churchill
