[OpenLayers-Users] Updating Data: Comet, Push, or What?
Michael
mdm at yachtpc.com
Fri May 20 12:13:18 EDT 2011
Thanks Arnie
You may be right, and certainly ARE right about sailboats being slow.
Actually, I don't care about latency much at all. In fact, we will
delay/obfuscate the data by as much as four hours anyway in order to
reduce tactical use by competitors. It's really the issue of an AJAX
request staying open on a conventional server apparently ties up resources.
Your suggestion of simply sticking with conventional polling, but
reducing the cycle count, is an excellent one, and a heckuva lot easier
to implement.
I had stumbled across websockets at the same link you provided just a
moment ago. I guess the issue there is it is not fully implemented or
deployed, but WILL BE.
I'M STILL interested in other views on this. With 90k visitors a day,
reducing server load while delivering an exciting experience is a good
thing.
Michael
On 5/20/2011 7:52 AM, Arnie Shore wrote:
> I'll certainly defer to others who've done measurements here, but from
> some experience with our open source computer-aided-dispatch application:
> WRT " ... It seems that the "long polling" method or, worse, looped
> queries, can lead to server overload ... ." I expect here that the
> culprit is in implementers trying to minimize latency by using an
> excessively short cycle period, which results in hammering the server.
> Riding to rescue is WebSockets -
> http://en.wikipedia.org/wiki/WebSockets - which supports server push,
> and for which many of us wait in eager anticipation. It's a nice
> solution to the general problem of http in a real-time environment.
> At this writing, the protocol spec is fairly far along but
> implementation is uneven. I'll guess that it might be widely
> available in the latest browsers later this year.
> Pending that availability, consider conventional solutions like those
> you've named, but with a reasonable cycle time. And live with the
> latency. (AS fast as these boats are, they remain sailboats!)
> AS
> On 5/20/2011 10:14 AM, Michael wrote:
> > Greetings Mappers!
> > I've built a trans-pacific charting application intended to be used for
> > near real-time sailboat tracking.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
