[OpenLayers-Users] Re: Updating Data: Comet, Push, or What?
Arnie Shore
ashore3 at verizon.net
Sat May 21 15:52:33 EDT 2011
Have you done any measurements that tell you where the server-side time
is going?
If it's database access - and you're satisfied that your schema design
is optimal - then solutions to that problem include some variations on
the following.
a. A caching mechanism that would update the cache at a rate you
select, rather than at the rate of visits.
b. Create a static page that often, and respond to users with that
static page.
Client-side, if memory is being consumed and not returned, then forcing
a page reload can clear that issue.
AS
On 5/21/2011 3:01 AM, Kris Geusebroek wrote:
> Hi all,
> A timer event would certainly work. Although i found that with Internet
> Explorer the memory consumption is huge. Every update will create new
> dom elements and the removal of dom elements is not freeing the memory
> out of the box.
> So whatever solution you choose you should take that in mind
> Cheers Kris
