[OpenLayers-Users] Re: Updating Data: Comet, Push, or What?
Michael
mdm at yachtpc.com
Sun May 22 09:37:18 EDT 2011
I have not done any measurements.
The advice on server load is entirely based on commentary on various
websites. I suppose, as I set this thing up, a test is a good idea.
The likely use case here is that there will be a few thousand users at
any one time who will need updates every five minutes or so. According
to what I have read, if I use a technique that holds a normal Apache
server connection open for each of those connections it will bog the
server down badly.
In fact, for the basic data upload, I am using the techniques you
describe. This is a matter of good design when more than one visitor is
expected! The concern I have is multiple long-polling AJAX calls.
Research continues....
MM
On 5/21/2011 12:52 PM, Arnie Shore wrote:
> Have you done any measurements that tell you where the server-side
> time is going?
> If it's database access - and you're satisfied that your schema design
> is optimal - then solutions to that problem include some variations on
> the following.
> a. A caching mechanism that would update the cache at a rate you
> select, rather than at the rate of visits.
> b. Create a static page that often, and respond to users with that
> static page.
> Client-side, if memory is being consumed and not returned, then
> forcing a page reload can clear that issue.
> AS
> On 5/21/2011 3:01 AM, Kris Geusebroek wrote:
>> Hi all,
>> A timer event would certainly work. Although i found that with Internet
>> Explorer the memory consumption is huge. Every update will create new
>> dom elements and the removal of dom elements is not freeing the memory
>> out of the box.
>> So whatever solution you choose you should take that in mind
>> Cheers Kris
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
