[OpenLayers-Users] proxypass and Proxy.cgi
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Mon May 23 09:04:20 EDT 2011
The OpenLayers example script proxy.cgi is not designed to solve this problem.
ProxyPass in Apache is a way to solve this problem, but won't really help you
if your webserver is IIS; I presume IIS has similar proxying capabilities.
Proxy.cgi is used to solve a different problem; if your OpenLayers content is hosted
on the same host/port/scheme as your geo server, then you don't need it.
-- Chris
On May 22, 2011, at 4:16 PM, ext Mustafa646 wrote:
> what is difference between proxypass and proxy.cgi ? why we use them?
> my OL application and Geoserver are both on same production server and i can
> access geoserver from outside world at http://93.45.32.11:8080/geoserver/web
> when Port 8080 is open in firewall. But, If port 8080 is closed, then i
> could not access http://93.45.32.11/geoserver/web.
> Now, for accessing  http://93.45.32.11/geoserver/web at port 80 (IIS is also
> at 80), whether i need proxypass or proxy.cgi ?
> i am confused between the two. What is the easiest and best solution so that
> i can access Geoserver at port 80 from outside world?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/proxypass-and-Proxy-cgi-tp6392306p6392306.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
