[OpenLayers-Users] Questions about Markers and Text markers
Nicholas Efremov-Kendall
n.e.kendall at gmail.com
Wed May 25 11:29:47 EDT 2011
My guess would be that one way to approach this would be to have an XML file
of your preference loaded into the side-bar and map at the same time. If you
set a listener to the list-item and it's related feature, you should be able
to get the functionality you're describing. Someone may have a more detailed
solution.
On Wed, May 25, 2011 at 9:48 AM, Miguel Chang <mac_luzer at hotmail.com> wrote:
> I want to show a sidebar with the information of the markers, kind of list
> where I could sort the data by date or by location and by selecting this
> list it directly shows me the position on the map.
> > CC: openlayers-users at lists.osgeo.org
> > From: n.e.kendall at gmail.com
> > Subject: Re: [OpenLayers-Users] Questions about Markers and Text markers
> > Date: Wed, 25 May 2011 00:49:34 -0500
> > To: mac_luzer at hotmail.com
> > Can you clarify what you're trying to do? By definition if you want to
> mess with the text on the client side you'll need jscript...which is what ol
> does.
> > Sent from my mobile device
> > On May 24, 2011, at 11:28 PM, Miguel Chang <mac_luzer at hotmail.com>
> wrote:
> > > Hello there, I´m implementing a web page using Openlayer as the map
> provider and so far it seems to work... but I have some troubles with the
> markers because I want to show the information both at the map and on the
> page itself, is there anyway to manipulate the data from text file once
> loaded? also I´m looking for a more direct approach on feeding the data,
> like extracting directly from a database, is there any implementation that
> does not involves a lo of javascript coding ?
> > > _______________________________________________
> > > Users mailing list
> > > Users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110525/a90e13e4/attachment-0001.html
